1 - 4 of 4 Posts
I just got a set of Thule Aeroblade Edge 7503 load bars for our new 2021 Trailhawk.
2396351606
Except in black.
Extremely hard to find; not available through Thule, and I seem to have gotten the last pair available from REI.
Not cheap, but the Thule WingBar Evo bars aren't available at all. And I like the integrated look of the Aeroblade Edge.
Wanted to stick with Thule since I've had Thule ski carriers with t-bolt mounts for many years.
2396351608
Just test-fitted the bars on the Trailhawk, and they seem really solid. Only thing I think I'll do is get some spare neoprene straps that secure the bars to the roof rails. The straps seem really tough, but if one's damaged or dry-rotted there's nothing else securing the bar.
So the fine graphic Thule instructions :cautious: say not to have them on while going through a car wash, for obvious reasons. Any one have these, and in defiance of instructions used an automated car wash?
Instructions say not to open a sunroof either with the load bars on, but the Trailhawk's sunroof works just fine with them...
Waiting on photos of them on your Jeep!
Well, OK. Here's how just the load bars alone look on the Trailhawk:
2396351612
Pretty unobtrusive, but that was the whole idea.
Here's how they secure to the rails:
2396351613
I thought at first that perforated strap that tightens round the rail was rubber, and I was afraid of it failing. But it's actually a thin steel strap, covered in thick molded rubber. It's not going to break.
Here's how the old Thule ski attachment looks with one pair of skis. Not too bad:
2396351614
There's just the two of us now, and two pairs will fit flat. If our kids visit, four pairs will fit bottom-to-bottom.
These are my old K2s, longer than my wife's; and they're well short of the antenna. The liftgate has a lot of clearance too.
The only challenge is how high the roof is particularly on this Trailhawk. Getting the load bars on and off isn't easy (remembering that I can't go through carwashes with them); neither is getting the skis on. The dual-pane sunroof (not MySky) slides back without problem, but it only goes halfway back. I might be able to get my wife to stand on the front seat and poke up through the sunroof to make sure everything is secured. Or I'll need a stepstool...
Wait... I just realized the convention is to mount a ski attachment to the passenger side of the car, so skis can be loaded and unloaded from the curb. I'll have to run out and reverse things... 🙄
...Done. The other thing to realize is, the roof rails aren't quite parallel; they narrow a bit toward the rear. At the positions where I've got the load bars, the rails are about 3/4" narrower at the rear than the front. So I have to position the front ski carrier about 3/8" farther over from the rail, to make sure the skis are lined up parallel to the vehicle's center line. Because I'm just that way.
The Thule pictorial instruction brochure says not to go through a car wash with these load bars, for obvious reasons.
But then again, it also says not to open a sunroof with the bars on.
Anyone routinely go through car washes (with rotary brushes) with these or similar load bars? They're a bit of a pain to put on and take off, and I'm washing the Trailhawk a lot since it's new... :)
Also, do you guys and gals remove the rubber flex antenna when doing a car wash? I have so far, but...
1 - 4 of 4 Posts
