The forum has been an incredibly friendly place. Here are my questions to make sure I am following so far...
My TrailHawk came standard with a 22x tire? The 22x is the width in mm? If I want to put a wider tire on the same rim I need to use something called a spacer? This "pushes" the tire away from the body so it won't hit the springs? A wider tire gives more traction because of a larger contact patch?
I have aluminum rims (stock)? For winter tires steel rims are better? Steel rims are heavier... what makes them better? Does the stock tire on the TrailHawk work reversed (there are some treads that work best in a single direction, from what I understand). What's a "normal" price for a set of rims, when should my, "I'm being ripped off" detector fire up?
I'd LIKE to get a set of rims and put winter tires on them. Can someone show me what a "good" set of winter tires are versus a "WOW" set of winter tires?
I have tried to do some research, if you know of articles to read, I am happy to educate myself. I'm just trying to avoid the, "Canadian air in your tires" routine...
Thanks for anyone that takes time to help me understand this better. If it helps I live in Colorado, and I'm talking deep enough snow...
