1 - 9 of 9 Posts
Tirerack has the renegade in its configurator.
You can check out what 17", 18" tires there are.
Discussion Starter · #2 ·
The Trailhawk tires they show are pretty much street tires and wont do squat for off road. I found these.
http://www.yokohamatire.com/tires/detail/geolandar_a_t_s
http://www.tirepros.com/tire-detail...59&filterVehicle=1&b=/index.php?q&style=35764
That link for the BF Goodrich is awesome but im skeptical of it because that size for the TrailHawk isn't avail on their official website in the K.O. Tire. and apparently the geolandar isn't as well on their respective website.. :(
If we can get some BFG KO's for this thing that will be great!! 5 years on a used set and not one leak, flat, or puncture. Very durable, long lasting tire!
Yeah, tire rack and a few others agree that unless the renegade can take a 15 inch rim, there is no KO tire sized right.
For the geolander, there is a 215/65/16 which would fit if you get 16 inch rims, and there's a 225/65/17 that'd probably fit on the trailhawk ok. Probably. General tire has the grabber AT2 in 215/65/16 as well. ( http://www.tirerack.com/tires/tires.jsp?tireMake=General&tireModel=Grabber+AT+2 )
The closest thing I found to a good fit that's aggressively off-roady are these http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=Road+Venture+MT+KL71 in 225/75/16. Or these http://www.tirerack.com/tires/tires.jsp?tireMake=Firestone&tireModel=Destination+M/T also 225/75/16.
Actually if 225/75/16 fits, there are a decent number of LT offerings in that size. It only adds about .2" width wise, but basically an inch and a quarter of height. So no idea if the trailhawk lift would make it fit.
The 215/65/16 will fit the Latitude/Sport models with the 6-speed manual as that is the standard tire size. I also noticed that the geolander comes in 225/55/18 which is the standard tire size on the Limited. So those are some options for those not getting a trailhawk but who still want an A/T tire.
They'll fit a trailhawk, you just need wheels to go with it.
1 - 9 of 9 Posts
