Ive got a 2018 jeep renegade with a 6 speed manual transmission that feels like the transfer case is in neutral. You let out on the clutch in any gear and there is no rpm change or grinding or any sign of anything engaging. The clutch has normal tension and you can see the shift linkage moving as it should at the transmission. Shifting between any of the drive modes has no effect at all and there are no trouble codes... ideas?
