Trailhawk All Terrain A/T Tire & Wheel Alternatives
333084 Views 269 Replies 111 Participants Last post by  MightylilRen
Tire Size Alternatives
With the release of the Trailhawk close at hand and no sign of the promised Falken WildPeak A/T 215/65R17 tires I went searching for possible alternative A/T tire sizes for the Trailhawk, since the stock 215/65R17 is an uncommon size. Perhaps Falken is just running behind schedule with their development and they will be available soon?
I’ve searched dozens of tire sizes, brands and models. This first thing I learned using the 1010tires.com Tire Size Calculator was this pop-up warning:
Quote:
WARNING!
When changing tire sizes, we recommend staying within 3% of the diameter of the original tire. Any more than this and you face the risk of brake failure.
So I present the Trailhawk Alternative Tire Size Analysis, PLEASE READ the Analysis Table Notes, in the next post.
--Another Trailhawk Tire Info Thread:
Wheels and Tire Specs
See less See more
Reactions: 5
1 - 20 of 270 Posts
Analysis Table Notes:
(1) Stock Trialhawk Tire Size is 215/65R17.
(2) Best Fit to Avoid getting Jeep Factory Warranty declared Void?
(3) The 225 size tire is .4" wider, .2" on the inner side that may cause rubbing.
(4) The 235 size will require New Rims or Wheel Spacers to avoid rubbing.
(5) 1010tires Recommends to be +/- 3% in Diameter Variance to your stock tires:
http://www.1010tires.com/Tools/Tire-Size-Calculator
http://www.tacomaworld.com/forum/tirecalc.php?tires=215-65r17-215-70r16
(6) The combined Tire and Wheel Weight, if it exceeds stock, may have a negative impact on drivetrain wear.
(7) Jeep lists the Falken Wildpeak in the Renegade literature and they claim it is being developed.
See less See more
Reactions: 1
Size Selection & Warranty
Beyond the 3% WARNING! Diameter Variance rule, discussed above, that I'm also concerned about any possible impacts to the 9-speed automatic transmission, suspension and drivetrain component wear, but that is just the beginning. I want to make sure I have NO Impact on: Comfort, Road Noise, Handling, Steering, Braking, Alignment or Tire Wear.
Well okay, of course, there will be some compromise from a highway tread tire, but I’m speaking of trade-off between different brands and models of All Terrain A/T tires.
But MOST IMPORTANTLY: NO Impact on the Jeep Factory Warranty
So after reviewing the information tire size alternatives, perhaps the Best Size Selection may be the 215/70R16, for the reason being it is the same width as the stock tire and it is .15 inches shorter that the stock 28" tire height. This may help from Jeep claiming a larger diameter tire size contributed to any warranty claims you may have and saying you voided your warranty.
See less See more
Reactions: 1
Lift
If you want to gain some Lift from larger/taller tires, the 225 or 235 will do it. However, what still has to be determined is will these sizes, on a stock Trailhawk, fit within the stock wheel wells?
Could you try for a taller 215 size tire, perhaps, what does your research show?
http://www.1010tires.com/Tools/Tire-Size-Calculator/215-65R17/215-75R16/215-85R16#.VOoBvpHDiGg.email
Again, the impact on your Jeep Factory Warranty, by running these size tires, needs to be determined.
Reactions: 1
Wheel Size, Diameter and Offset
Depending on the tire size you select, if you have to buy new wheels you will lose the cool looking Trailhawk wheels, with the red Willy's on them, but that is the trade-off that has to be made. Perhaps a cool off-road rugged looking wheel will make the Trailhawk look even better.
So the next challenge is to find alternative 16” or 17” wheels, with the Renegade’s 5x110mm bolt pattern. The stock offset is ET40, but with the 225 or 235 tire size this may need to be different.
The Cherokee also uses the 5x110 bolt pattern so that may help when searching for alternative wheels.
Please post photos and links to any potential wheel alternatives you find.
Best Brand & Model Tire for the Trailhawk
What is the Best Brand and model tire to choose for the Trailhawk? Well of course that is somewhat subjective, what combination are you looking for, Ride, Handling, Mileage?
For me, the Best combination of On-Road Comfort, Minimum On-Road Noise and Good Off-Road Traction. Review of surveys such as the one at Tirerack and others helps:
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=ORAT
For example, in the 215/70R16 size, the Yokohama Geolandar A/T-S has the Lowest Noise, Best Comfort and Good Dry Traction.
http://www.tirerack.com/tires/surve...ameter=16&showwp=N&showdp=N&showws=N&showcm=N
What Brand and model best fits your needs?
See less See more
I was looking at this stuff last week. It seems the Trailhawk tire size is just very unusual. Based on the fact that I won't be doing any rock crawling, I decided I may be better off going with the Latitude with the 1.4L turbo and that way I can get the 6-speed manual too.
The standard tire size on the manual Latitude is 215/65/16, and there are a ton of A/T tires available in that size including both the Yokohama Geolandar and General Grabber AT2. I think the Grabbers look like the better tire (I love the more rugged look), but I'd have to do some reading to determine which is best. But either way, you seem to have a lot of choice at that size.
Ok - please educate me here. The Renegades all come with tires, right? Are the stock tires so bad that it's common to immediately go out and spend an extra $1000 or so on new ones? What do you then do with the brand new stock tires?
I'm not sure about the trailhawk tires, but I suspect some folks want a more aggressive tire for off-roading.
As for me, I would get the trailhawk for sure if it came with the 1.4L turbo & manual transmission. But since it doesn't, I think I may get the Latitude and then throw some AT tires on it as the Latitude just comes with regular all season car tires and I want something more rugged.
Reactions: 2
The stock Goodyear Wrangler SR-A® that come on the Trailhawk have a reputation for not being the longest lasting nor the best off-road traction, in the A/T class of tires. If Jeep is able to actually get Falken to come through with the promised WildPeak A/T tires we may be fine.
Some people also will go to a more aggressive or larger tire just because they think it looks better, hey, it's a Jeep!
Reactions: 1
Really nice work. Much appreciated.
Reactions: 1
As that old Michelin commercial used to say, "there's a whole lot riding on your tires." Tires are the most important part of the vehicle. The ones Jeep uses as factory equipment are usually garbage. Take an unmounted Goodyear ST or SR-A tire and pinch the inner/outer sidewalls with your thumb and fingers...it'll scare you to death. I don't want that on a Jeep with my family inside and I especially don't want to take those off the pavement.
New tires are around $500 a set, then you sell your take-offs on craigslist for $250 and you end up spending $250 on the best upgrade you'll ever make to your Jeep. Ever. www.discounttiredirect.com
Reactions: 1
Depends on the tires. my subaru came with the bridgestone potenza re92 (or RE92A forget which was the "special" oem coding). I've never in my life driven on more scary tires in the wet (lateral traction? what's that?), and I've bought cheap non-name store brand tires as a youngster. I ate the $500 and the tire store did whatever they wanted with them.
Car before that, OEM was a perfectly OK tire, but I wanted different wheels and tires. SO I took them off early, and slapped them back on when I sold the car.
The other option is to have the tire shop pull the tires off, and put the tires online cheap on a model specific forum, or your local craigslist or whatever. If you are not using the wheels either, hold onto them and keep an eye on the WTB. Someone WILL be messing up their OEM wheels, and they will need replacements and givien the absurd price of OEM replacements form the manufacturer, they are worth some decent cash. For example, my subaru, I had a blowout due to a too delicate tire brand vs. NJ potholes at highway speeds, and ate a wheel in the process. Cost to replace was about $300. THe businesses that specialize in selling used OEM wheels wanted about $240. You could move them as fast as you wanted at about $160 a pop on subie forums after the car was on sale for about a year.
See less See more
Reactions: 1
The tyres installed OEM in Renegade Trailhawk have better fuel efficiency than, for example, Yokohama Geolandar G012 that are rated "F" for fuel efficiency (European Union tyre label).
Your correct, A/T tires will reduce your fuel mileage. If you want a Trailhawk for its looks alone or to take on some mild dirt roads or trails the OEM tires will be fine for you.
If you want to go on more challenging offroad routes, deeply rutted, washed out trails, rocks or boulders you need more agreesive treads on your tires. This also helps to keep your tires intact on the wheels when you hit a sharp rock or tree stump as many tires with agreesive treads have heavier sidewalls.
It really comes down to how and where you want to USE your Trailhawk.
Reactions: 1
Do we know for sure if any larger tire would void the warranty? Even if it's around 3% bigger?
They can't specify replacement parts. Even for tires labeled exactly the same, there are a range of actual measured diameters despite the sidewall label. On top of that, the OEM selection of tires on the same drive train from the factory are fairly different. On top of THAT, there just aren't that many choices of tires that will fit at all.
I think the reality is that without a lift kit, you won't have a choice of something likely to cause debate of the subject.
With a lift, if a lift is a thing one can get done on the renegade, it will not void the warranty on anything other than stuff immediately affected by the lift, wheels, and tires.
A quick example of a few scenarios.
You do a lift with bigger tires, strut spacers, and wheel spacer to get everything to fit. It looks hella cool, but...
a) your air conditioner stops working. They can't deny because your changes have nothing to do with that.
b) your wheel bearings die a very early death. They can and should deny that, because with spacers you changed the offset of your wheels and thus increased stress on the thrust bearings. You might get away with it, but the most likely culprit is your modification of the vehicle, and a denial is justified.
c) You hit a vicious pothole and your suspension mount rips through the body. They'll deny you lift kit or no, because you struck something. Lift kit has nothing to do with the denial, even if the lift kit was designed like crap and exacerbated the situation.
d) The car keeps on overheating. This would depend on the design of the vehicle. Bigger tires can make the tranny and engine work harder. That could lead to overheating, especially if the design of the vehicle uses the radiator to cool the transmission fluid. However, they should perform diagnostics and warn you you will be billed if it is related to the modifications. If they find a bum circuit breaker or fusible link is causing the fan to not cycle properly, that is MUCH more likely to be the culprit and should be warrantied as it has nothing to do with your modifications. Similar if they find a coolant leak that doesn't look to have been caused by the monkeys who installed your kit. If they find something they can argue is the result of faulty work, it's not warrantable, you need to take it up with the hack who damaged your vehicle.
You want a fully intact warranty, don't mess with stuff too much.
See less See more
In order for a warranty to be void, the dealer has to PROVE that a failure was cause by an aftermarket part. Out of all the stuff I have done/ seen done/ have had friends do in all my years of over 25 years on modifying cars- I have never see a warranty voided over tires. Now suspension alterations, intakes, programmers, pulley's, down pipes, fuel injectors and what not yes, but never tires.
Thanks guys, I'm really hoping to not mess with it much, probably drive stock tires for a bit and then maybe see how I feel about ~29" tires. Would I need a lift or anything for that slight of a size bump? Sorry, I don't know much about car mods but I'm excited for this thing!
The bigger problem is finding rims that aren't ricer rims that have a 5X110MM bolt pattern. I want these or something close but none are made.
See less See more
Reactions: 3
1 - 20 of 270 Posts
