1 - 5 of 5 Posts
I hit a tree in my rear bumper recently. I now have a small hole, anyone have an extra? Or know how hard it is to swap out if I buy the MOPAR OEM
If you don't have an OEM hitch and you want one, might also be a good time to consider it. regardless, on top of the bumper skin, make sure you order about 6 to 10 of these, they are less than a buck each, you will likely need at least 4, better to have more on hand
5SR17JXWAA
CLIP-RETAINING
Good idea on checking the hitch install. Depending on where your hole is located you might be able to get away with just putting a hitch on, being that you have to cut the bumper anyways to access the receiver!!! Best of Luck
1 - 5 of 5 Posts
