Status
Not open for further replies.
1 - 1 of 1 Posts
· Premium Member
Bulletin numbering:
The first two digits of all TSB numbers represent the category group.
The middle two (or three) digits denote the category issue sequence.
The last two represent the calendar year in which the TSB was issued.
A letter at the very end, starting with "A", designates a revision and/or update, and supersedes the prior bulletin.
05 - Brakes
05-007-15 (EMEA only)
-Front Brake Squeak/Squeal Noise
vehicles built on or before February 25, 2015
05-010-15
-Brakes squealing
05-001-16 REV. D
-traction control light comes on when making tight turns on vehicles equipped
with AWD
-Electronic Parking Brake (EPB) does not disengage when accelerating while the
"Auto Apply" feature is selected.
-key may get stuck in the ignition key cylinder.
-EPB does not engage with the “Auto Apply” feature selected."
05-002-17
-Anti-Lock Brake System (ABS) Module Enhancements
The traction control light comes on when making tight turns on vehicles equipped with All Wheel Drive (AWD).
Electronic Parking Brake (EPB) does not disengage when accelerating while the "Auto Apply" feature is selected.
key may get stuck in the ignition lock cylinder.
07 - Cooling
07-007-15
-ENGINE COOLING:COOLING SYSTEM:RADIATOR ASSEMBLY
THERE IS VIBRATION IN THE STEERING WHEEL WHICH MAY BE CAUSED BY CLEARANCE BETWEEN RADIATOR ANCHORING PIN AND RADIATOR SUPPORT RUBBER BUSHING
08 - Electrical
08-023-15 REV. A (North America Markets Only)
-Stored Diagnostic Trouble Codes (DTCs) Found During New Vehicle Preparation
08-026-15 REV. A
-Incorrect Language Displayed On The Cluster And Radio
vehicles built on or before March 03, 2015 (MDH 0303XX) equipped with one of the following radios:
*Uconnect 3.0 AM/FM (sales code RA1).
*Uconnect 5.0 AM/FM/BT (sales code RA2).
*Uconnect 8.4AN AM/FM/BT/ACCESS/NAV (sales code RA4)
08-052-15
-Compass Direction Displayed Is 90 Degrees Off
vehicles built on or before April 23, 2015
08-053-15 REV. A (Brazil only)
-Cluster Backlighting Dimming Incorrectly
08-058-15
-Vehicle Will Not Start
vehicles built on or before March 02, 2015
08-060-15
-Doors May Not Unlock Using Remote Keyless Entry (RKE)
08-062-15 REV. B
-RA2, RG2 Radio Software Enhancements
vehicles built on or before March 02, equipped with UConnect 5.0 AM/FM/BT (sales code RA2)
PASSENGER MAY BE EXPERIENCING POOR BLUE TOOTH COMMUNICATION. MAY REQUIRE RADIO SOFTWARE UPDATING
08-066-15 (U.S. and Canada only)
-Improvements To Messages Displayed In The Cluster
vehicles built on or before April 02, 2015 equipped with Cluster 7.0” TFT Color Display (Sales Code JAJ) or Cluster 3.5” TFT Monochrome Display (Sales Code JAY).
08-071-15 (NAFTA, EMEA)
-BCM Update To Correct Various Symptoms
vehicles built on or before June 16, 2015
08-073-15 (Brazil only)
-False Vehicle Security Alarm Activation During Surveillance Mode
vehicles built on or before July 3rd, 2015
08-077-15 (NAFTA or EMEA)
-RA4 RG4 RJ4 Radio Enhancement
vehicles built on or before June 25, 2015 equipped with one of the following radios:
* 5N AM/FM/SXM/HD/BT/NAV Radio (Sales Codes RA4).
* 5N AM/FM/SXM/HD/BT/NAV Radio (Sales Codes RJ4).
*5N AM/FM/SXM/HD/BT/NAV Radio (Sales Codes RG4)
08-078-15 (U.S. and Canada Markets Only)
-Antenna Mast Will Not Screw Into Base
vehicles built on or after April 12, and on or before June 12, 2015 equipped with UConnect 5.0 AM/FM/BT (Sales Codes RA2)
08-084-15
-ELECTRIC POWER ASSIST SYSTEM
JEEP RENEGADE: POWER STEERING SYSTEM WARNING LAMP WILL ILLUMINATE ON INSTRUMENT CLUSTER. ELECTRIC POWER STEERING MODULE NEEDS REPROGRAMMING WITH LATEST SOFTWARE
08-094-15
-PARK ASSIST MODULE NEEDS REPROGRAMMING WITH THE LATEST SOFTWARE AVAILABLE DUE TO A NON START UP
08-033-16 REV. C
-UCONNECT Software
08-065-16 REV. A
-Beats Audio System Enhancement
Amplifier Audio Enhancement
08-016-17
-Radio Software Enhancements
Bluetooth communication with the passenger is poor. The UConnect microphone
may not amplify the voice of the person speaking from the passenger seat. (2015
BU Only).
False message may be displayed in the cluster; Parking Sensors Unavailable and/or
Sound System Unavailable (2015 BU Only).**
Radio display screen may intermittently go blank.
Back up display may not turn off.
08-031-17
SUBJECT:
Flash: BCM Diagnostic And System Improvements
SYMPTOM/CONDITION:
Customers may experience one or more of the following conditions listed below:
• **The horn will sound when locking the door using the door panel switch while the door is open.**
• Power driver’s seat will not move and active Diagnostic Trouble Code (DTC)
B1062-11 - Electric Seat Movimentation-Circuit Short To Ground, will be set (2015 - 2016 Only).
• If a vehicle has been started using the remote start and the door panel lock switch is pushed before the ignition has been turned on, the vehicle shuts off (2015 - 2016 Only).
• When ParkSense is turned off, the LED on the switch will turn on indicating the system is disabled. On the next key cycle the system is still disabled, but the LED on the switch will not turn on (2015 - 2016 Only).
• Rear interior overhead lamps remain illuminated after exiting vehicle and locking from the driver's or passenger's door lock buttons. This is causing the vehicle battery to go dead (2015 - 2016 Only).
• The door locks are inoperative when locking/unlocking remotely (2015 - 2016 Only).
• False activation of the vehicle security alarm (2015 - 2016 Only).
• False exterior light failure messages being displayed in the instrument cluster (2015 - 2016 Only).
18 - Performance
18-043-15 REV. A
-2.4L Powertrain Diagnostic And System Enhancements
vehicles built on or before June 30, 2015 (MDH 0630XX) equipped with a 2.4L engine (Sales Code ED6) and 948TE transmission (Sales Code DFH)
18-060-15 (NAFTA)
-Flash: 1.4L Diagnostic And System Improvements
vehicles built on or after February 02, 2015 (MDH 0202XX) and on or before August 21, 2015 (MDH 0821XX) equipped with a 1.4L Engine (Sales Code EAM) and a 6-Speed C635 Manual Transmission (Sales Code DE1)
21 - Transmission
21-030-15 REV.A
- Transmission Shift And Drivability Enhancements SOME CUSTOMERS MAY EXPERIENCE A MALFUNCTION INDICATOR LAMP ILLUMINATION
vehicles built on or before May 6, 2015 (MDH 0506XX) equipped with a 2.4L engine (Sales Code ED6) and 948TE transmission (Sales Code DFH).
21-032-15 REV. A (NAFTA, EMEA)
-Transmission Shift And Drivability Enhancements
HAVING A HARSH SHIFTING OR TO UNABLE ENGAGED GEARS OF TRANSMISSION. MODEL 2015
vehicles built on or after May 12, 2015 (MDH 0512XX) and on or before July 8, 2015 (MDH 0708XX) equipped with a 1.4L
21-038-15
-Drivetrain Control Module C2020-01 ECU Internal Fault setting in the DTCM
vehicles built on or before May 19, 2015 equipped with All Wheel Drive (Sales Code DFH).
21-040-15 (International Only)
vehicles built on or before May 25, 2015 equipped with a 2.0L diesel engine (Sales Code EBT) and 948TE automatic transmission (Sales Code DFH)
21-048-15 REV.A
-ALL WHEEL DRIVE LIGHT ILLUMINATING DUE TO DTC MAY BE EXPERIENCED BY SOME CUSTOMERS. PROCEDURE ON REPROGRAMMING THE DRIVETRAIN CONTROL MODULE WITH LATEST SOFTWARE
21-053-15
-ERRATIC TRANSMISSION SHIFT QUALITY MAY BE INDICATED
21-054-15 (NAFTA and EMEA)
-Flash: Vehicle Will Not Shift Out Of Park
vehicles built on or before September 30, 2015 (MDH 0930XX) equipped with 9-SPD 948TE (Sale Codes DFH) or 6-SPD C633 (Sales Code DA1).
22 - Wheels
22-001-14 REV. A
-Steering Wheel Vibration Diagnostic Procedure
23 - Body
23-020-15 (Latin America Vehicles Only)
-Replace Missing Manual Release Cover For The Electric Fuel Door
23-025-15 (Brazil only)
-Rear Door Glass Stain
vehicles built on or before May 09, 2015 with sales code XL9 – Portuguese (Brazil) Language
23-030-15 (NAFTA, LATAM)
-Door Noises And/Or Door Functions Inoperative
vehicles built on or before February 24, 2015
23-022-16
-MYSKY sunroof panel noise
24 - Heating & AC
24-003-15 (NAFTA, EMEA)
-Air Conditioning Inoperative
vehicles built on or before June 23, 2015
24-004-15 (LATAM/BRAZIL ONLY)
-Air Conditioning Performance
*(PM me if you found any to add)
1 - 1 of 1 Posts
Status
