After doing some searching and testing it myself I can confirm that if you delete a message from your phone it deletes it from the Uconnect system. However you have to disconnect and reconnect the phone for it to re-sync the address book. If you're still seeing messages on the Uconnect and you've already deleted them from your phone I would delete the phone from the Uconnect and re-pair. I'm using an Android phone btw.I cannot find the text messages anywhere on my phone, so I do not know where or how to delete these text messages from my phone. Any specifics on where these messages would be on my phone would be greatly appreciated. Many Thanks.
Have you tried to un-pair and then re-pair your phone to the Uconnect system?I also have Android and I have 0 uconnect shown text messages on my phone, while I have 35 of them on my uconnect system. Don't know where to delete these messages on my phone. Any ideas?
hi do i need to be connected to the u connect when i delete the messages?After doing some searching and testing it myself I can confirm that if you delete a message from your phone it deletes it from the Uconnect system. However you have to disconnect and reconnect the phone for it to re-sync the address book. If you're still seeing messages on the Uconnect and you've already deleted them from your phone I would delete the phone from the Uconnect and re-pair. I'm using an Android phone btw. I hope this helps!
Hi sheilamccormack99! If you need any additional support, our team is available via private message anytime to assist.hi do i need to be connected to the u connect when i delete the messages?
