For those of us with a uk multijet, manual with no start button. I’ve discovered this method to reset the oil change message at home without a £70 trip to Jeep.
After months of trying to reset this message here’s what worked for me.
Worked on a 1.6 multijet diesel 2015 manual longitude.
1-turn on the ignition key,
2-press the gas pedal and hold it,
3-press the brake pedal 7 times without releasing the gas pedal,
4-keep pressing the gas pedal for 60sec.
5-Release the gas pedal and turn of the ignition key,
6- Wait for 60sec.
Then turn on the ignition key and start the engine. Check if the service/oil change light turned off.
I’ve seen many posts about this from uk folks I hope this helps!
I had to restart my car 10 times to make sure it wasn’t a trick and it had actually gone 😂
6- Wait for 60sec.
