@Jeep Jon - On Hill Descent Control (HDC)... First, my automatic doesn't have the button either. The 75th Anniversary hard copy brochure I have lists under capabilities: Active Drive, Active Drive Low and Selec-Terrain System. In the Renegade hard copy brochure I have, in the specification section under Safety & Security it lists HDC as only being available on Limited and Trailhawk. There's an asterisk against Limited which then says 2.0 Multijet II 140hp 4WD Auto Low Limited only. Looking on the main US Jeep website it doesn't properly explain which models have HDC, although the way it's positioned implies that it's only on the Active Drive Low models. It's definitely there on the 75th Anniversary page on the website, but I guess we don't have it. And I don't know of any 75th Anniversary models with Active Drive Low...
@david_terrar . The saga continues... are you sure you don't have HDC on your automatic? I'm getting a bit confused now over the spec as I checked out these ones for sale, and the pictures clearly show HDC on these automatics. Is it because mine is manual I don't get the HDC (as the brochures didn't explain this clearly that by getting the manual you sacrifice HDC). If yours doesn't have HDC and is automatic it looks more likely Jeep have messed up the build somewhere or there are more variations than the 3 we are lead to believe? And that could be a serious issue that is due rectifying.
Green 2.0 automatic, the select terrain system is clearly split into 3 sections:
http://www.autotrader.co.uk/classif...ort=price-asc&make=JEEP&model=RENEGADE&page=1
Green 1.4 automatic, the select terrain system is clearly split into 3 sections:
Manual 2.0 like mine, no HDC on the select terrain system:
Depending on if your automatic is indeed missing HDC, this would imply there were variations even within what Jeep sold, the 3 variants, with some having the Active Drive Low technology, and some not? But there were 3 only on the configurator which is why I'm confused. Just don't want us to have been missold nor Jeep to have made a build mistake.
