I'm seeing Renegades populate some dealerships but the only specifics are the VIN.
What can we decode from the VIN about a car that's listed with no info?
Thanks folks.The door sticker will tell you month and year of manufacture.
https://jeep.custhelp.com/app/jeep/eqlisting_detail/session/L3RpbWUvMTM5MzY0MzI4OC9zaWQvWGxOMmc2T2w%3D
That link will you give you a build sheet
In VINs from Europe:I'm trying to figure out how the VIN number advances based on the build date of the vehicle. From what I know, the last 8 digits of the VIN number are reserved for the Manufacturer to have a sequence number for when that vehicle rolls off the line. The first two characters of that 8 digit code are always letters. My theory is that the letters seem to point in some way to the month it was built.
For example, I found a Renegade on a local lot with this VIN:
ZACCJBCT1FPC12890
It's build date was July 2015.
I've seen other vehicles where those two characters are PB (Instead of PC).
Are there vehicles with "PA" in those two characters out there? What are the build dates of the PA and PB vehicles?
If you could post your letters and build date here, it may help decode what those letters mean.
I wonder if all of the PB VINs were built in the beginning of 2015, like maybe Jan-Jun? Perhaps PA would be Jun - Dec 2014 (Just a guess).In VINs from Europe:
-First 2 digits identify the country of origin/manufacturer
-3rd digit is 9
-Digits 4-9 identify vehicle characteristics (model/trim/equipment)
-Digits 10-17 identify vehicle specific information
Your target here, digit 12, falls in that last group that identifies things like specific site of construction, date of manufacture, shift, number within a certain lot produced that day or shift, etc.
It might indicate shift (maybe they introduced a 3rd shift after they got comfortable in Melfi or something), but it also could have to do with the opening of some alternative plants around the globe, depending on where you found it.
FWIW, mine is PB, built 2/2015.
They will always have the Italian VIN. While the standard bearers are slightly different, they reciprocate and accommodate each other's formats around the world. US Departments of Transportation just accept our Italian VINs.I wonder if all of the PB VINs were built in the beginning of 2015, like maybe Jan-Jun? Perhaps PA would be Jun - Dec 2014 (Just a guess).
Perhaps you're right, and that it means nothing with regard to date of manufacturer, but rather some other arbitrary indicator that means something to FCA.
Also, since this vehicle is made in Europe, will it get a European VIN? Or do they put US VIN plates on vehicles destined for the US?
Same here.FWIW, mine is PB, built 2/2015.
I guess I don't see where you are going with this. Are you trying to find a way to determine build date by looking at the VIN ? There is not enough information in the VIN to accurately determine the build date. Just open the door and look.So far, my theory of PB = Jan-Jun 2015 build date and PC = Jul-Dec 2015 is holding up.
