1 - 5 of 5 Posts
I can send you four of them with Pirelli P4 tires on them in exchange for a set of OE 18" wheels. The tires only have about 4k miles on them.
Measure the distance between the centre of 1 stud hole to the next. Then measure the diameter of the middle opening.
Those are very important sizes for fitting any wheel to the Jeep.
1mm out of alignment means it won't fit. :cry:
I only mention this in the off chance that the 215/65/16 which is the tyre size you need, could be fitted to a NON Jeep wheel. You could in turn be sent a wheel that is not of compatible measurements.
It's only a thought as I am sure no-one will try to rip you off :unsure::whistle:
Keep in mind that different car manufacturers wheels also fit the jeep. Ford Ranger I believe may be compatible. However I am unsure of the shape of them.
1 - 5 of 5 Posts
