1 - 10 of 10 Posts
hey guys my driver door squeaks when doing off roading...when the body is tweaking a little on rough roads...found out it is the door weather stripping ...lubed with wd-40 and it went away for a while and now it's back and dirty too...anybody had this problem...what sprays or wipe ons is everybody using....dry lube...silicone...graphite...something that won't attract dirt....thanks for any insight..
Don't have any thing like that on our BU. But on my JK I use 100 % silicone on all my bushing after cleaning it up from going off road. Last trip off road I started do it to the BU also.
Hope that helps.
I wouldn't use '40.
I'd suggest a good silicone grease.
It apparently has the added benefit of "plumping-up" the rubbers.
That's why it is commercially used on Breathing Apparatus for example Firefighting or Scuba Diving to keep the O-rings lubricated and plumped up.
Full support for Nev's recommendation from me.
I had not fully read the original post. Therefore as IDMOR suggests will be the better solution no pun intended. (A solution of soap and water).
When dry it won't attract the dirt as easily as some wet solutions like 40.
1 - 10 of 10 Posts
