Hey has anyone replaced there front wheel bearings. I need to do my passenger front. Of course the dealership said no way due to life tires and wheel spacers.
Why do you have to replace it so soon? If it helps my front lower control arms were bad, and I have a stock TH, dealer replaced them no issue or questions asked
A bad wheel bearing will initially make a whining or droning noise that eventually ramps up to something that sounds like a helicopter gunship is following you closely. Grinding noises may also emanate from a damaged wheel bearing. The bad wheel bearing will get noisier in curves on which the damaged bearing's load increases (right wheel bearing gets louder in left curves and vice versa)I think it's my bearing. Going over bumps it sounds like my tire is going to fall off. Something is loose. I don't think the dealer will do it because of the mods. Maybe it's worth a shot.
Yeah, commonly you will feel and hear some grinding when spinning the defective bearing - depending on how much damage has already occurred.??????
Lift which ever tire you believe has the bad hub, spin it while you've got your hand on the strut. Usually you can feel the feedback from the bad hub/bearing
