61 - 80 of 211 Posts
2015 Trailhawk
Anyone know if these will fit on the Renegade Trailhawk?
I'm waiting for some Yokohama Geolandar A/T-S tires in the same size to replace the stock tires on my Trailhawk. Tire guy said they'd fit. Hope so.
2015 Trailhawk
Still waiting for my stupid tires. Ordered them around the first of the month, and they were supposed to take a couple of days to be shipped to my local Belle Tire store. About ready to go to another tire store.
2015 Trailhawk
Tires being installed as we speak - pics and impressions forthcoming!
2015 Trailhawk
Yokohama Geolandar A/T-S 225/65/R17 on my Trailhawk.
They seem to fit without rubbing. No major change in road noise of ride quality.
Looks really good! Does your car have the stock suspension?
Do you think 225 70 R17 will fit with a 1" lift kit? I think so, if your tires fit perfectly with the stock suspension.
2015 Trailhawk
Yep, stock suspension. I'm affraid I don't know much about spacers and lift kits. Hopefully someone with knowledge of those thongs can help you out.
2015 Trailhawk
That looks good. Any noticeable change in acceleration or the MPG on the display?
Tire guy told me when the speedometer says I'm going 60, I'll actually be going 61.1. Haven't really driven on them long enough to say how fuel economy is affected.
Yeah, speedo will be 1.8% off, so you are actually going 1.8% faster than what it says with that size. I am really tempted to go buy some, im curious to see if you notice any impact on fuel economy though. My fuel economy has been pretty bad, I dont want it to get any worse.
What about road noise (mainly highway)? They look good btw.
TS
Reactions: Hypocrite
This thread is amazing. Great stuff!!
I assume this will be even harder with a limited (which I have) sport and lattitude as they are lower. Correct? I'd need a 1-2" lift kit before playing around with steelies and wheels?
Trailhawks are only 0.3 inches higher than other 4x4 Renegades and have the exact same suspention movement. I'm planning on upgrading my (or soon to be my) latitude to 225/70-16's which run the same or just slightly taller than a trailhawk's 215/65-17's (28" in diameter vs. Latitude/sport/limited 27"). I'm most likely going with Hankook Dyna Pro ATM RF10's which come in at 28.4" inches in a 225/70-16. This should get me within 0.1" of a trailhawk's stature with a tiny bit less wheel-fender gap.
-Jason
How about the tire monitoring system any issues? Also looking pretty slick as was looking for a good AT that is good onroad and offroad.
2015 Trailhawk
No issues. I believe the sensors are connected to the valve stems, and they just kept the original ones on the new tires.
Reactions: smithk1944
Discussion Starter · #80 ·
Tire pressure monitoring system will still work if you swap them from the stock wheels. I'm using my mud tires as a second set so I didn't swap the sensors. I'm not sure if a second set of sensor will work without programming.
With the mud tires on without sensors, I get a warning low pressure on the dash when I start the car and the small warning light stays on. I wish I could deactivate the system.
