1 - 7 of 7 Posts
I still have the stock WildPeak H/T’s on my 2017 TH. There are a crapload of tire posts here……I would recommend using the search function.
I need to start considering tires also.
I did try the search function and everything I found includes using some sort of lift. I got some Toyo All Terrains 225/60R18 for a good deal on Amazon. Hopefully they will work. Any insight before I put them on will be helpful.
2016 Longitude 4x4
I think that type of question is on here on quite a few threads but that doesn't necessarily make it easy to find: you may find it easier to search based on the size you are thinking of rather than 'largest size' or similar.
The answer is usually 225/60r18 or 225/65r17 although with spacers/different offset wheels and the pinch seam mod you can go a bit bigger (search will reveal a few guides to this if you want to go further or plan a small lift)
Hello BTW!
Ah….You have an Altitude. I believe the tire sizes differ from the TH. Make sure any tire recommendations you get are specific to your model.
1 - 7 of 7 Posts
