Will the Renegade be capable of towing much?
35514 Views 15 Replies 12 Participants Last post by  kaufmanj1973
The jury is still out on whether the Renegade can really be called an off-road vehicle, but what I am wondering if if Fiat-Chrysler also took care to make sure that the Renegade is capable of towing. What's the point of being an off-road capable vehicle if you can't even tow your trailer or boat to a campsite.
Do you know/think that the Renegade will be capable of towing much, or is it too small to really take on a task like that?
1 - 16 of 16 Posts
Also note the auxiliary transmission cooler is not included with the tow package, so make sure you order it.
Reactions: 1
So that's not a crazy big amount but I guess you can't expect too much from such a small vehicle. What type of stuff weighs around 2,000lbs, like what could you tow with the Renegade. A boat? A trailer? ???
Not much.... I would say a pair of Jet Skis, a Small pop up trailer or a snowmobile or to pull your cub cadet around on a trailer or something.
i wouldnt go about towing with it very often
too much strain on a 4 cylinder
Is that 2000-pound towing limit official from FCA? What is a limited based on: frame structure? engine capacity? cooling mods? All of that? Any reasonable way to increase capacity?
Yes, that is from the official spec sheet. It is all of those and brake capacity. You could try a hemi upgrade, looks like it fits, you just need to snip a little sheet metal:
See less See more
Hey... Omaha Orange is at least the right color for a HEMI!!!
If a Cherokee Trailhawk with the 2.4 is rated for 2000 pounds, I very much doubt the Renegade would be any higher.
Towing maximum capacity
For EMEA models
http://www.fiatpress.com/download/2014/schede_tecniche/Technical_Sheet_Jeep_Renegade_ENG.pdf
2.4 l Multiair II (only available on some markets): 907 kg = 2000 lbs
1.4 Turbo Multiair (4x2 and 4x4 versions): 1000 kg = 2205 lbs
same for 1.6 diesel and 1.6 gasoline engined
2.0 diesel engines: 1500 kg = 3307 lbs
For U.S. version should be 2000 lbs for the gasoline 2.4 engine, for 1.4 Turbo Multiair II = "not recommended"
See less See more
We can’t say for sure, but we’re guessing it’s towing about 2500 pounds with that U-Haul trailer it’s got hooked up in the back. That’s well within the 3,300 pound stated towing capacity for this very off-road worthy crossover vehicle.
http://www.tflcar.com/2014/06/2015-jeep-renegade-high-altitude-tow-testing-spy-shots/
It is normal in product development to test your product in excess of the final specification. So if you put a street rating of 2000 pounds tow capacity the you want to stress test it high to see how it behaves.
It is also possible they were testing the EMEA models:
For EMEA models
it should be able to pull a 8 foot U-Haul trailer without much problems. My old Hyundai Excel could do it.
Hmm. That's an old (June) TFL post, and the towing capacity is given at 3300 pounds. That would be nice if true. If.
One of the few things that disappointed me about my 2017 Renegade. I got the 1.4 with manual tran, and find that you can't tow ANYTHING with it, they recommend never towing anything. I had a 3-cyl Mitsubishi Mirage with manual transmission that could tow up to 1200 lbs.
1 - 16 of 16 Posts
