Hm. Sounds like a design oversight.
Yep. Spoke with the shop foreman. He said FCA likely did not test any type of situation with a crosswind, because it's very reproducible with the other Renegades on their lot. Probably just wind test from the front. No idea...Hm. Sounds like a design oversight.
As soon as I get it back, I will do this immediately.Can you post a picture of the holes that were taped shut? I'm sure many of us want to check our doors.
Don't forget. It's "special wind quieting tape which prevents rust".Oh boy, my new $20K-$30K Jeep Renegade was repaired at the World Class FCA Dealership:
Yup. With all the other known issues out of a very small pool of cars now in the US (and how FCA is handling them), it's looking more and more like there will be no Jeeps in my future.Oh boy, my new $20K-$30K Jeep Renegade was repaired at the World Class FCA Dealership...
Oh! I wonder if that was done intentionally, anyone have the service manual or subscription?That round hole at the top should have a black plastic cushion-type plug in it... check your other doors. My driver's door is missing it, the other three doors aren't.
I mean, Christ on a bike, what is going on with quality control over in Melfi?!
My drivers door has one. FWD Latitude. So, unless you have a TH and it is intentional for some reason, you probably should have one. I have slight wind noise on mine, but I don't notice any more. The only thing I do notice is that there must not be as tight of a seal as my last vehicle, because if I drive by a stinky place and have recycled air on, I can still smell it inside my Renegade which shouldn't be the case.Oh! I wonder if that was done intentionally, anyone have the service manual or subscription?
Thanks,
A
Wow, that is new to me. I wonder if our US models have/will get this. Does your door make any whistling around that area?Hi,
I am Eric from The Netherlands and been driving a Renegade 1.4 Multiair since November 2014.
In the top of the door is a rubber stop.
In the 3 bottom holes they have welded a small plate which leaves an opening in the top of the hole.
See attached pictures.
This wouldn't happen to be Bakersfield Jeep/ Fiat/ Chrysler would it? This is standard issue for them.I have attached two pictures showing the patented drain tape.They taped over the drain holes, as wind was going up through the bottom drain holes which resulted in wind noise. I can attest it did indeed cure the symptoms. However, I obviously don't approve of covering of drain holes. Water remains in the door, and now we hear a sloshing of liquid when closing the door.
They alleged that "poking small holes" in the tape would help water drain. I had inquired about this when we took it back. However, the tiny bits of plant material have clogged this up. Really I should have asked, if it was designed to be taped...why are there holes in the door to begin with? El-Oh-El.
Built in whistle, sometimes used for drainage. Doors hold water so when you get thirsty, you can quench by using a crazy straw through your drain hole.
Great fix. *sarcasm*
I do not endorse this fix. FCA approved this and I think it's garbage.
https://drive.google.com/open?id=1YTwml_eBOcIA3PeIa0k-YT7rUPJrjK7FGQ&authuser=0
https://drive.google.com/open?id=1y1_1O1kpRELdeHH8hVuzGQJYlbD-WkhjLQ&authuser=0
The Renegade will be back at the dealer today. This is absolute rubbish. Won't be accepting a fix that will result in premature rust perforation.
