1 - 9 of 9 Posts
2015 Trailhawk
Hi everyone, this is my first post but I recently replaced my valve cover gasket on my 2015 trailhawk and found that the plastic wire harness channel was completely broken. Not only the clips had snapped but the channel itself was broken in 3 or 4 places. After cleaning out the old broken clips from the holes ontop of the cover I realized that the cover in fact had threads tapped into it (M8-1.25). So I called up the dealership to see about getting a new plastic channel that I could then bolt on instead of using these worthless clips.
To my dismay it turns out they don’t actually sell that part stand alone, in fact you need to buy a whole new wiring harness. I felt this was absurd since that’s would cost a few hundred dollars. So I just cut all the zip ties off and made my own out of aluminum. I figured I’ld share it in the hopes it helps someone else. I mostly used hand tools, jigsaw, drill, vise and ball ping hammer. Hope it’s of some use.
2396348565
2396348566
2396348567
2396348568
2396348569
Pretty impressive metal work right there. I found myself in a similar situation when the powered sunroof broke. It was just a simple plastic clip that probably would’ve cost $1 stand alone, but was only available if you bought the entire MySky roof, an estimate of $4500.
Welcome to the forum!
2015 Trailhawk
Discussion Starter #3
Hey thanks a lot! Bummer about the clip. It’s so frustrating when they won’t part out things like that.
and enjoy the forum!
DId you check any junk yards?
Welcome to the forum and thank you for an extremely pleasing first post containing pictures and detailed instructions.
I love it :love:
1 - 9 of 9 Posts
