1 - 4 of 4 Posts
Maybe you could "make" it fit, but I doubt it will bolt right up.
Looking at the exhaust, I'd say that if you want side exit, you'd be better off getting it fabricated locally. What's there is not that complex and even seems press bent. Which means you just need someone with some tig welding skills and a lift to get similar.
The underside of the Jeep is going to be all different, although the flange for the exhaust is probably the same. So it would probably bolt on, but it will probably interfere with something under the body. If you decide to buy it and try it, let us know
1 - 4 of 4 Posts
